Group: DynoMotion Message: 10739 From: rjreese29@ymail.com Date: 12/29/2014
Subject: G0 rapid not moving in mdi
I am just setting up, and have not done a lot of testing to find out what my real issue is, but wanted to reachout to see if this has been encountered before.
I am using mach3, and commanding a move in mdi when in modal G0 results in no movement. G1 does have the expected movement though.
What I have obserdeved is that when I input a move in mdi when in g1 will result in movement for all respective axis. when I switch to g0 and command a move it does not move, I enter back to g1 and enter a commanded move and there is no movement until I turn reset off then on(just software mach3 reset). when the software is reset, it works again (only in g1 though)
I have not tested gcode in mach3 or kmotioncnc, but will tonight. I have not tested mdi in kmotion either.
If you have any immediate solutions, it would be greatly appreciated. Otherwise I will do so more testing and get back to you with more information later.
Greatly appreciated,
Rob
Group: DynoMotion Message: 10740 From: tmday7 Date: 12/29/2014
Subject: Re: G0 rapid not moving in mdi
Hi Rob,
 Are entering the MDI command as one line of code, like this for example?
G00 X-2.
Troy
Group: DynoMotion Message: 10745 From: Rjreese29 Date: 12/30/2014
No. I separated them.
Get in g0 modal first... Enter.
then enter the commanded move.
Unfortunately I couldn't do testing last night to provide more info.
Thanks for asking.
Rob
On Dec 29, 2014, at 6:23 PM, tmday88@... [DynoMotion] <DynoMotion@yahoogroups.com> wrote:
Hi Rob,
G00 X-2.
Troy
